Inventor Forum
Inventor 2009 installation problem on Windows 10 - Application Error 0cx0000142
6 REPLIES 6
3143 Views, 6 Replies
Having used Inventor 2009 on Windows 7 for some years it was inevitable that i would end up with a Windows 10 OS. Following a successful installation of Inventor 2009 when launching i get an application error message 0cx0000142 appearing. I had tried playing around with the compatibility trouble shooter and even re zeroing the DLL register but still no luck! Can anybody please advise if there is a way out of this and what i might need to do in order to fix the issue?
Many thanks.
6 REPLIES 6
mdavis22569
2009 won't run on Windows 10 ...it's not supported.
The best I've seen is 2014 with some adjustments needed ...
It's time to upgrade Inventor ...sorry
Mike
Mike Davis
in reply to: mdavis22569
Hi Michael,
Thanks for your reply. Maybe i will have to downgrade my OS and go back to Windows 7!! Windows 10 causes nothing but problems!
Thanks again for your reply.
mdavis22569
if you can do a rollback I would ..
We're still on Windows7 here ..and a few other of my Cad Admin friends are as well.
Mike Davis
The earliest version of Inventor that will run on win10 is 2011 (but it will need all service packs & updates/hotfixes installed).
Chris
Chris Mitchell
PDMS Customer Engagment Team
Autodesk, Inc.
Chris
Are they officially supporting it then?
Mike
Mike Davis
ChrisMitchell01
What do you mean by "it"?
Inventor 2011 is no longer officially supported but win10 definitely is. We officially support Inventor back to Inventor 2014 as of now. (Current release plus 3 versions back).
Chris
Chris Mitchell
Autodesk, Inc.
