Recently tried to install Inventor 2020 on my work machine and get the following error through ADA:
The 2147943860 error code comes up as -214794386 when I click "search for a solution" which brings up nothing. Searching for the 2147943860 also brings up nothing. I manually updated Visual C++ using both the 2012 redist (why?) and most current redist, both x86 and x64 which my machine is and this did not fix it. Deleting temp files and reattempting the install through ADA did not work.
I next tried a manual install and got this:
Doesn't make enough sense to me to try any specific troubleshooting approach.
Computer has all drivers updated, most current build of Windows and Windows Update shows everything is up to date. Computer was freshly booted from a fully shut-down state prior to both installation attempts. Reviewing the logfile from the first install doesn't reveal anything helpful to me, the 2012 x86 redist install just fails and the installer aborts. Wasted most of my morning on this, any suggestions would be much appreciated.
