Inventor Forum
Inv. 2008 Thumbnails in Win7 Explorer?
11 REPLIES 11
Message 1 of 12
Cnoj
667 Views, 11 Replies
Is there a way to make this work? I see thumbnails in the Inventor file dialogs but not in Win7 Explorer.
I'm using Win7 Enterprise 64bit and inv 2008 SP3.
Also my machine came with a Autodesk32bitExplorerLauncher.bat (below). Anyone know what it's for?
jon C.
Autodesk32bitExplorerLauncher.bat:
@echo off
REG QUERY "HKCU\Software\Microsoft\Internet Explorer\Main" /v "Window Title"
if %ERRORLEVEL% EQU 0 goto :Restore
:ECHO Delete
REG ADD "HKCU\Software\Microsoft\Internet Explorer\Main" /v "Window title" /t REG_SZ /d "Autodesk 32-bit" /f
start %windir%\SysWOW64\explorer.exe /separate
timeout 2
REG DELETE "HKCU\Software\Microsoft\Internet Explorer\Main" /v "Window title" /f
goto :EOF
:Restore
:ECHO Restore
FOR /F "tokens=3* delims=	 " %%a IN ('REG QUERY "HKCU\Software\Microsoft\Internet Explorer\Main" /v "Window Title"') DO set Title=%%b
timeout 2
:echo %Title%
REG ADD "HKCU\Software\Microsoft\Internet Explorer\Main" /v "Window title" /t REG_SZ /d "%Title%" /f
:EOF
Inventor 2013/Pro SP2
SimCFD 2015 SP2
Win7-64bit
11 REPLIES 11
Message 2 of 12
ampster40
in reply to: Cnoj
works on Win7/64.  Not sure what that bat file is for.
CC parts don't display but user created part files show in thumbnails;
Message 3 of 12
Cnoj
in reply to: ampster40
Isn't that the 2010 icon in the corner of your thumbnails?
In 2008 all I get is:
SimCFD 2015 SP2
Win7-64bit
Message 4 of 12
ampster40
in reply to: Cnoj
it's the 2011 icon.
Have those files in your screenshot been saved to 2008, the version you are using?
If they are of an older version, that is one reason the thumbnails won't show.
edit, let's check your Win7 folder view settings;
Open up Windows Explorer, then click on the "Organize" button in the upper left corner and select "Folder and Search options".
On the next window, click on the "View" tab.  On that screen, there should be an option to enable called "Display file icon on thumbnails"
Is that enabled?
Message 5 of 12
Cnoj
They're all generated in Inv.2008 on either XP 32 bit or Win7 64. I could see thumbnails for these files on my 32bit XP machine..
SimCFD 2015 SP2
Win7-64bit
Message 6 of 12
ampster40
in reply to: Cnoj
I just tried disabling that Folder option I previously mentioned and I could still see thumbnails, so that must not be the correct Win7 setting to enable thumbnails...will keep searching!
Message 7 of 12
Cnoj
Yup I have it enabled but it seems to make no difference.
Jon C.
SimCFD 2015 SP2
Win7-64bit
Message 8 of 12
ampster40
in reply to: Cnoj
have you tried a simple test of creating a new part on your Win7 pc, then check to see if you see the thumbnail for that part?
What does iProperties > Save tab look like for you after starting a new part file?
I don't believe those options changed much and you should have a "Save Preview Picture" option enabled there.
Message 9 of 12
Cnoj
Yup got Save Preview Picture > Active Component Iso View on Save enabled.
Another thing I noticed - no iprops access via windows. In XP the properties for an inventor file had an 'iProps' button on the properties tab that let you view/edit custom iProps etc. No such button now.
SimCFD 2015 SP2
Win7-64bit
Message 10 of 12
ampster40
in reply to: Cnoj
OK, I believe 2008 on 64bit may be the issue here but not certain.
I don't remember if 2008 had a problem like this, but on 64 bit systems you didn't have a Pack n Go option from Explorer back then for example.
Might want to look into compatibility on 64bit systems with 2008.  There might be some limitations.
Sorry but I don't have any other suggestions.
Message 11 of 12
Cnoj
Well thanks for trying. I'll post here if I find out anythign further.
Jon C.
SimCFD 2015 SP2
Win7-64bit
Message 12 of 12
Cnoj
in reply to: Cnoj
Just an FYI:
Win7 is reading the thumbnail data from inventor files, it's just not displaying it in file icons.
It's using it for folder icons however:
Just hoping to pique someone's curiosity 🙂
Jon C.
SimCFD 2015 SP2
Win7-64bit
