Intersection curve not updating on 3d sketch
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Seems like an odd behavior to me... just looking for confirmation that Inventor should be able to do the following:
Two intersecting surfaces are used to project a line onto a 3d sketch using the "intersection curve" tool. The curve is created successfully and indicates it is constrained to the underlying surface being projected as expected. However, when the surface being projected is moved relative to the surface being projected to, the curve in the 3d sketch remains in the same position relative to the part's coordinate system. Consider that the two surfaces are normal and remain normal to one another even after the projected surface is being shifted. Ie the projected surface is being shifted parallel to the surface being projected to.
This is a part file. Single body with 3 surfaces. Inventor Pro, 2015. No errors are being thrown.
