Inventor Forum
Internal error in persistence operation - can't save Assembly
4 REPLIES 4
999 Views, 4 Replies
Can anyone tell me if there is a fix for this problem?
Running IV6, WinNT5 sp6a
Getting the following Error message while trying to save an assembly (that
was previously savable).
We have tried to remove the part that was added right before the problem
began.
Bill
[WARNING] Problems encountered while saving the document.
[r:\core\Fw\Main\FWxSceneDoc.cpp, line 1431]
[ERROR] Error(s) detected while writing segment AmDcSegment in database
C:\WINNT\Profiles\cad7_nt.000\Desktop\temp\Final Assembly.iam
[r:\core\RSe\segment\segStream.cpp, line 242]
[ERROR] Error detected while saving object of type RDxOccurrence
[r:\core\RSe\meta\meta.cpp, line 967]
[ERROR] Internal error in persistence operation (Segment loading
is not supported within other persistence operations)
[ERROR] The database in C:\WINNT\Profiles\cad7_nt.000\Desktop\temp\Final
Assembly.iam could not be saved
[r:\core\RSe\database\databaseC.cpp, line 1195]
4 REPLIES 4
began.
Bill
I'm getting the same error... Anyone have any ideas? Bueler... Bueler... Bueler...
[ERROR] Error(s) detected while writing segment AmDcSegment in database G:\1INVENTOR\Parts & Assemblies\E-Size\EX\EX20046.iam [r:\core\RSe\segment\segStream.cpp, line 242]
[ERROR] Error detected while saving object of type RDxOccurrence [r:\core\RSe\meta\meta.cpp, line 967]
[ERROR] Internal error in persistence operation (Segment loading is not supported within other persistence operations)
[ERROR] The database in G:\1INVENTOR\Parts & Assemblies\E-Size\EX\EX20046.iam could not be saved [r:\core\RSe\database\databaseC.cpp, line 1195]
Tools>Rebuild All on the assembly, any
subassemblies, and any parents of derived parts in your assemblies.  (Don't
try to save until you've done it to all of 'em!).
The word from Adesk (via my VAR) is that SP1 will
fix it, but this is the workaround for the time being...
Cheers!  Alan
I'm
G:\1INVENTOR\Parts & Assemblies\E-Size\EX\EX20046.iam <RSeRes(622)>
RDxOccurrence <RSeRes(1408)> [r:\core\RSe\meta\meta.cpp, line 967]
persistence operations) <RSeRes(623)>
Assemblies\E-Size\EX\EX20046.iam could not be saved <RSeRes(202)>
Thanks, I'll give it a try and post the results...
Rick
