Instance Property read only
gopinathmY575P
Message 1 of 8
gopinathmY575P
Hello all.
In Bill of material panel, for some library part I cannot be able to switch from Custom iProperty to Instance Property, say read only. why?
Replies (7)
Message 2 of 8
CCarreiras
Usually a Library part is read-only file, so you cannot change/save the file.
Copy the file for a non Library folder and replace it in the assembly. Now it is a "normal" file, and you can do changes and save the changes.
CCarreiras
Message 3 of 8
gopinathmY575P
for most library parts its working, only few experience this behaviour!
Message 4 of 8
CCarreiras
All that parts are in the same folder?
CCarreiras
Message 5 of 8
gopinathmY575P
So, file is checked out by someone else and is unavailable for edit in the library itself., so that it went read only
Message 6 of 8
gopinathmY575P
Yes ,in the library directory. Part is checkout by someone so it went read only
Message 7 of 8
CCarreiras
Every Library file (in a folder Library): and if that folder is set in project file as a library folder, should be read only by definition...
CCarreiras
Message 8 of 8
gopinathmY575P
we restrict the network drive access to ready only for general user to access library parts. We are controlling like that.
