Inventor Forum
installing inventor 2015 ultimate
3 REPLIES 3
safiredesignengineers
408 Views, 3 Replies
hi group
I guess this might be a silly question but i would like to see if others have done it?
I don't have enough room on drive C to install inventor 2015 ultimate but i do have a drive 😧 that has 460gb, is it possible to just install it on drive d:?
regards Adrian
hi group
regards Adrian
3 REPLIES 3
johnsonshiue
I don't think installing Inventor in a drive other than C: would be an issue. However, Inventor and other Windows applications utilize the temp folder under user profile to store temporary files for application specific operation. It seems that your C: drive is running low, which is not good for all applications. Can I ask why you could not relocate some of the files in C: to 😧 and keep your program files in C:?
Thanks!
Software Test Engineer
Thanks!
JoyceZhou
Yes, the installation space for 2015 Ultimate is a little big, about 60GB.
You could change it to other driver (eg. 😧 ), then the space requirement for C: will be less to only install some necessary files. see the attached image.
Joyce-Jinghua Zhou
Inventor QA Engineer
Joyce-Jinghua Zhou
Hi Thanks for your replies I do still have 80gb on drive c: but that is why i wanted to put it on 😧 and i wasn't sure if it would workwell like this but it looks like it will so i will install it on D    8-)
