Hi all
when QC asks for a markup drawing (dimensions are marked with a number or letter) to be used as references on the measuring reports I struggle to find a good solution.
1) I can make a dimension to an "Inspection dimension" - and add a number/letter. However, I cannot do this with a "Feature" - e.g. run-out. Also I cannot supress the inspection dimension (I do not want this to be part of the drawing that we send to subsuppliers). So this does not really full fill me needs.
2) I can make a "skecth symbol" (I choose a circle with a number inside) and place the sketch symbol net to all the dimensions and features that needs to be checked by QC. The problem is that I cannot "hide" or "suppress" my sketch symbol. So to do this I need to make a seperate IDW with the markup. And then if I update my drawing with a new dimension or a dimension changes I need to make another new draiwng and add the "sketch symbols".
It there an easier way to do this. What I would have liked was that I could have a "stamp" (e.g. a circle with a number inside) with a counter build-in. So every time I use the stamp the number increases by 1. This stamp I could then use on the drawing, print the drawing with the markups, "hide"/"Suppress" the "stamp" and then save the drawing as the one my supplier receives. Then If I need to make a drawing changes I just open the drawing, make the change, "unhide" the stamps (e.g. add a new stamp if a new dimension has been added), print for QC, "hide" the stamp and save the drawing again.
Ideally the stamps where connected to the dimensions and features and through this you could create a spreasheet of dimensions to be checked with tolerances and everything.
Bo
