Insert Object Issues
charrisML997
Message 1 of 8
charrisML997
When I go to insert an object (image) into a 2D Sketch within Inventor 24, the file coverts from JPEG/PNG to an HTML, and does not render when I press OK. Nothing happens.
Even if I try to save a picture into a Word Doc, it recognizes the file format and the cursor blue circle spins for a minute, but nothing displays.
I have tried accessing files from different locations / folders on my local drive, and that did not change the outcome.
I have also had issues inserting objects (PDFs) into Inventor DWG files.
Thanks for the advice re: how to correct these issues.
Best,
Colby
Replies (7)
Message 2 of 8
Frederick_Law
What is the "object"?
Which file format?  JPEG? PNG?
Where was the "object"?
Can you zip and attach the "object" here?
Message 3 of 8
charrisML997
Message 4 of 8
Frederick_Law
Use Insert image in sketch:
Message 5 of 8
Frederick_Law
Unless 2024 completely changed the process.
Message 6 of 8
charrisML997
Thanks for the suggestion. This does work to add the image to the sketch. I am still confused why inserting an object does not work, though.
Message 7 of 8
Frederick_Law
Which "Insert Object" command?
Message 8 of 8
Frederick_Law
Decal might be better:
This "Insert Object"?
