Hi all,
I have attached some photos about the shaft that I've designed for wind turbine. There are some loads and moments on the shaft. Is it possible to make calculation on shaft design with fabricated shaft?. Calculation is made as rough model, however modified shaft design, as you can see on picture, is forged.
You should still be able to run your own analysis on the part by going to the Environments tab > Stress Analysis.
I will tag the Dynamic Simulation Master here,
Would this be more of a situation for Dynamic simulation over standard Stress analysis?
Can you Attach your assembly here?
An assembly must include parts.
