Inventor Forum
Insert an Excel into inventor drawing
7 REPLIES 7
Message 1 of 8
3887 Views, 7 Replies
Hi!
I`m trying to insert an excel spread sheet in to inventor drawing, for some reason inventor cuts off 2 last rows. Is there a limit of how many rows can be inserted ?
it cuts off these two: see attached.
13.2    45FT     R2440    Gasket Material Vinyl Foam Strip 2" wide x .125 thk., Black, Weather-Resistant
14    12 TUBES    C11272    CAULK, SILICONE - CLEAR
Alex
Tags (1)
7 REPLIES 7
Message 2 of 8
CCarreiras
Hi!
It's working well in 2014.
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
Message 3 of 8
in reply to: CCarreiras
Well.... We are using 2012....
Message 4 of 8
CCarreiras
Hi!
Has to work also in 2012. Check if you are doing something wrong.
Check if you have installed all the updates for Inv2012.
CCarreiras
Message 5 of 8
Thank you, i tried 2 different ways using:
- Tools --> Paste Special
- Manage --> Insert Object
Both are cutting 2 last rows. Tried it on 3 different machines - same thing.
We use Inventor Suite 2012 64bit
Message 6 of 8
mpatchus
I seem to recall that at one point there was a limitation to the number of rows that could be imported.
Can't remember if it was for 2012 or not though.
Also check the Excel table for blank row or column.
From the 2012 HELP FILE....
NOTE:  Data is copied from the first worksheet only, starting at the specified cell.  When the source is an .xls or .csv file, data import stops when a blank row or column is encountered.
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
Message 7 of 8
mpatchus
in reply to: mpatchus
A couple of related posts I found...
http://forums.autodesk.com/t5/Inventor-General/Missing-rows-from-inserted-Excel-object/m-p/3499014/h...
http://forums.autodesk.com/t5/Inventor-General/Excel-BOM/td-p/3483948/highlight/true
Font size in the Excel spreadsheet seems to be a common culprit.
Inventor 2025 Beta
Message 8 of 8
Thank you. Changing font to a smaller font allows to bring entire sheet.
