Thanks Kent
It worked fine.
I did try zooming to extents to no avail. I since found with a similar
file that would not load , that if I copy paste it into a new drawing in
AutoCAD
and then Purged it, it worked. I think it is because there was a block that
would not Purge in the original drawing, may have been an X ref.or similar.
Many thanks again for your help.
Graham
"Kent Keller" wrote in message
news:6DA3A44AB7E4B6474195676AC5E89459@in.WebX.maYIadrTaRb...
> Graham
> I was able to bring it into R7 without any problems. It was way away from
> the origin, so I opened the AutoCad file and moved the modelspace lines
over
> to 0,0,0, and then brought it into a new sketch. Could it have been that
it
> was too far away from the origin that you weren't zooming out enough to
see
> it?
> I posted the file back under yours. You should be able to open it in R6.
> Kent Keller
> http://www.MyMcad.com/KWiK/Mcad.htm
> Assistant Moderator
> Autodesk Discussion Forum Moderator Program
> "Graham Watton" wrote in message
> news:C304D9BCDCC7D6FB3790B37FAB0051AC@in.WebX.maYIadrTaRb...
> > Just 2D into a sketch.
> > I start with a sketch in inventor import dwg and follow the wizard
> including
> > the option button.
> > Thanks for the offer I will post an example to you on Monday
> > news:557B8A4CAE2767D34A9387925EDDD7DD@in.WebX.maYIadrTaRb...
> > > What are your exact steps... is this 2d or 3d data. If you want to
zip
> > up and post a
> > > example AutoCad file to IVCF I am sure someone will take a look at it
> and
> > give some
> > > feedback.
> > > Kent
> > > Assistant Moderator
> > > news:A7861E90EA23D944B232776E81223C05@in.WebX.maYIadrTaRb...
> > > > I am having problems importing some simple dwg files into 6.
> > > > I have tried 2002 and MDT files. I have purged these files. I have
> tried
> > > > Model and Paper space inputs but all I get is the Thumbprint image
> > before
> > > > loading but no image in the Inventor file. I have had success with
> some
> > > > files but most are a problem. Am I missing something or is there a
> > problem
> > > > with the translator.
> > > > Help Please.
> > > > Graham
