injection mold design in inventor
Message 1 of 10
Capture1.PNGhello,
I am using inventor 2018 for mold design of plastic part. when I generate the core and cavity , that time it show some problem " some faces haven't been split at their silhouette" in parting diagnostics of generate core and cavity . can you describe what is meaning of that and how to remove that problem.
I have attached the photo of this problem .
Replies (9)
Message 2 of 10
TheCADWhisperer
Can you attach your *.ipt file here?
Message 3 of 10
sorry , I cant attached the product file because this is against customer policy .
Message 4 of 10
hello, generally I want to know what is meaning of that problem "sinhouette on the faces". can you describe and suggest  some tutorial how to rectify this problem?
Message 5 of 10
kelly.young
Autodesk Support
Autodesk Support
Hello @Anonymous not sure what you're trying to do, but here are a few links that might help explain what the error is referring to:
Silhouette curve
Split faces, trim solids, and split solids
How to split mold on tangent of circle & Curve
MOLD Design - cutting surface
Please select the Accept as Solution button if a post solves your issue or answers your question.
Message 6 of 10
Steven_Gao
Hello manojthapaermech,
These problems are only warning messages for you. "some faces haven't been split at their silhouette" means the parting line/surface may not on the silhouette curve of this part. You MAY need to modify the parting line/surface based on your design purpose. "Undercut Faces" has the similar situation, it means some of the part cannot pull out normally. However, if you want to design some inserts in these areas, you can ignore these warning messages. If not, you can use draft to analyse the part to get more detailed problematic areas.
Steven
Steven Gao
Fusion & Inventor Quality Assurance
https://www.autodesk.com/campaigns/fusion-360/insider-program
Message 7 of 10
hello
Draft analysis in inventor, there is any tool like probe so we can examine the draft of any face of part except only colour examine.
Message 8 of 10
kelly.young
Autodesk Support
Autodesk Support
@Anonymous the draft analysis gives the color values, do you have an example of what you are wanting the probe tool to do?
Message 9 of 10
hello,
Just like solidworks, if we want the draft of any face of solid we just click the face and its show the value. like this there is any option in Autodesk inventor which show the value of draft of any part's face in draft analysis.
Message 10 of 10
kelly.young
Autodesk Support
Autodesk Support
Hello @Anonymous there is an idea that is similar to your request that you can vote up.
IDEA: Inventor draft analysis
