Inherit properties from base - update by iLogic rule
Assume the following situation:
  • I would like to create a base part having e.g. 10 fx-properties (height, width, length, thickness...)
  • I need 20 "derived" parts that should inherit exactly these 10 part properties
  • I want to define the parameters values for each 20 part instances in the assembly
  • Later I want to be able to add another parameter to the base part and it should be available to all 20 instances
I tried to derive from the base part (among other things...)
Using a rule setting the fx-properties didn't work because they are readonly for derived components
Still looking for a work process to handle this scenario efficiently (Beginner).
Any recommondations?
Thanks for your time 🙂
CCarreiras
Hi!
You just have to link the properties (PARAMETERS) between the assembly and the parts.
You can do this easily with a basic iLogic rule.
You can input values in the assembly enviroment and the values goes to change the parts within (or not ) the assembly.
CCarreiras
Hi Carlos,
not sure if Iunderstand correctly. I checked out the possibilites with the linked parameter.
However, the properties are in my scenario still readonly.
Here is a sample project containing:
- A master part (MasterRectPipe)
- Derived parts DerivedPartA + DerivedPartB
- A MasterComponent as a target for links from DerivedPartA / DerivedPartB
I placed a rule in the MasterComponent to change the linked values but it's not affecting anything.
I placed a form to change the linked values but it's not allowing to change the values.
Propably  because of the readonly state of the properties...
What should work differently in your mind?
