Infinity Loop Tube Design
engineeringYR7JU
Message 1 of 12
engineeringYR7JU
I am trying to make an infinity loop out of 1.25" tube for a dance studio. These are basically two identical rolled tubes that are attached together. The problem I am having is where the loop crosses itself in the middle. I am trying to form the tube where it is offset at the point of intersection. I hope this makes sense. I have attached the sketch of half the loop. Its overall width and height are critical.
Thanks for any help you can give.
Inventor Pro 2025
Casey
Accepted solutions (3)
Replies (11)
Message 2 of 12
kacper.suchomski
Hi
You should also include a hand-drawn sketch of the desired outcome.
Kacper Suchomski
Message 3 of 12
engineeringYR7JU
Hope the sketch helps.
Message 4 of 12
kacper.suchomski
Just draw a side sketch that shows the bending of the material, then use the curve intersection tool in the 3D sketch. This will give you a path that will look like an 8 from above and a slight trough from the side.
Kacper Suchomski
Message 5 of 12
engineeringYR7JU
Is there a video somewhere on how to do this?
Message 6 of 12
kacper.suchomski
Kacper Suchomski
Message 7 of 12
Pineapple2024
IV2023
Message 8 of 12
engineeringYR7JU
Pineapple2024,
Thank you very much for taking the time to do this. I have never had to do anything like this. Even though it looks fairly simple. I am used to flat parts only. I will look at this more after the weekend. Again, I thank you very much.
Message 9 of 12
engineeringYR7JU
Pineapple2024,
The only issue I am having is with the constraints and getting all of the parts to align and miss each other.
Message 10 of 12
Pineapple2024
Model it flat.  Whoever welding it should be able to "twist it" to fit.
Make the 2 loop and fit straight to them.
Message 11 of 12
SBix26
Here is what @kacper.suchomski was suggesting, a 3D sketch curve created by the intersection of two 2D curves.  After creating half of the loop, I simply patterned it 180° to a new solid body, ready for welding at each end as you showed in your sketch.
The attached file is Inventor 2025 format.
Sam B
Inventor Pro 2025.1.2 | Windows 11 Home 23H2
Message 12 of 12
engineeringYR7JU
That is exactly what is supposed to look like. I appreciate you taking the time and effort to do this. I will take what you have shown and explained and use it for future projects.
