Index was outside the bounds of the array
hey everyone,
I have this code that reads the length of the array and also sorts the plane distance and for some reason i get an error
Index was outside the bounds of the array iLogic
Dim PlaneX = Double
Dim PlaneY = Double
Dim lenX = 0
Dim lenY = 0
For
Each xVar In PlaneX lenX = lenX + 1 Next For Each xVar In PLaneY lenY = lenY + 1 Next For j = 0 To lenX-2 For h = 0 To lenX-2-j If PlaneX(h) > PlaneX(h + 1) temp = PlaneX(h + 1) PlaneX(h + 1) = PlaneX(h) PlaneX(h) = temp End If Next Next For j = 0 To lenY-2 For h = 0 To lenY-2-j If PlaneY(h) > PlaneY(h + 1) temp = PlaneY(h + 1) PlaneY(h + 1) = PlaneY(h) PlaneY(h) = temp End If Next Next
johnsonshiue
Hi! I thought VB's array started with 1, not 0.
Many thanks!
Software Test Engineer
hey, thanks for the reply
i tried changing it to 1,but i still get the same error
SharkDesign
Think that error message means you are referencing a line in an array that doesn't exist.
So maybe you have 5 lines in the array but one of your lenx equations is asking for 6.
That's what I understand by that error anyway.
  Inventor Certified Professional
Thanks for your reply.
I have tried to delete some values from the excel and still i get the same mistake.
what I have also noticed is, the components on PlaneX are getting updated and when it's switiching to PlaneY it stops and i get that error
johnsonshiue
Hi! The syntax does not look like VB. Is it VB? You need to declare array like the following.
Dim PlaneX (10) As Double
Dim PlaneY (10) As Double
Many thanks!
hey,
thanks for the idea, but i have found the mistake.
someone changed some user paramters and they where lower the what the code was suppose to read, hence the error.
