Index out of Range Error
erobinsonMRQE2
erobinsonMRQE2
I am working on rule to insert virtual parts into an assembly based on known user parameters and a list of possible virtual parts.
I am encountering the an issue at the end of the rule where I get the error
Error in rule: Erase, in document: VirtualPartsModelAssembly.iam
Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: index
The rule runs and successfully creates the parts but shows the error at the end.
'Sets up Document
Dim oAssyDoc As AssemblyDocument
oAssyDoc = ThisApplication.ActiveDocument
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = oAssyDoc.ComponentDefinition
Dim oOccs As ComponentOccurrences
oOccs = oAssyDoc.ComponentDefinition.Occurrences
'Deletes any existing virtual parts
For Each oOcc In oOccs
	If Not oOcc.suppressed Then
	If TypeOf oOcc.Definition Is VirtualComponentDefinition Then
		oOcc.Delete
Next
'Defines Parts to Look at
'Dim PartList As New ArrayList
'PartList.Add("Lid") '0
'PartList.Add("Module") '1
'PartList.Add("ModuleFrame") '2
'Logger.Trace("PartList")
'Virtual parts
Dim VirtList As New ArrayList
VirtList.Add("Bolt") '0
VirtList.Add("Nut") '1
VirtList.Add("Washer") '2
VirtList.Add("Gasket") '3
Logger.Trace("Virt List")
Dim m As Integer
If OutletModuleQty = 1 Then
	'Defines the number of modules
	m = Outlet1LHQty + Outlet1RHQty 'User specified number of parts
	Logger.Trace("OutletQTY")
'Defines number of virtual parts
Dim iQty As Integer
iQty = m
Logger.Trace("iQty")
'Defines Virtual Part to create
Dim oString As String
For Each oString In VirtList
	Vstart :
	vPart = VirtList.Item(i)
	i += 1
	Logger.Trace(i & "VirtList")
	'Defines location for Virt Part
	Dim identity As Matrix
	identity = ThisApplication.TransientGeometry.CreateMatrix()
	Dim index As Integer
	index = 2
	Logger.Trace(index)
	If vPart = "Washer" Then
		'Loops back to bypass creating a virtual part
		GoTo VStart
	Else
		iQty = m 'defines number of virtual parts
	'create first instance of the virtual part
	Dim virtOcc As ComponentOccurrence
	virtOcc = oOccs.AddVirtual(vPart, identity)
	'add next instance starting at instance2 (if applicable)
	Do While index <= iQty
		oOccs.AddByComponentDefinition(virtOcc.Definition, identity)
	index += 1
	Logger.Trace(index & "Index")
	Logger.Trace(iQty & "iQTY")
	Loop
Next
Justin.B.
You're accessing each string in VirtList with a For Each loop, and also using i to access each VirtList.Item. But then:
	GoTo VStart
at this point you're still in the same "Washer" step of your For Each, and i += 1 gets run a second time. vPart is no longer "Washer", and you move on to the next item. But now i is out of sync with the For Each loop, which moves on from "Washer", and increases i again. Since i is one ahead, VirList.Item(i) is trying to access an item past the end of the list, and giving an index out of range error.
If your intention is to bypass "Washer", then instead of going back to VStart try wrapping everything in:
	'Do nothing
Else
'Run your code
