Dimensioning of an ellipse segment
sezak99
Message 1 of 8
sezak99
How do I dimension a segment of an ellipse in Inventor drawing?
Replies (7)
Message 2 of 8
andrewiv
I'm not quite sure what you're asking for. Is it something like this?  Maybe if you did a screenshot showing what you're trying to achieve.
Andrew In’t Veld
Designer / CAD Administrator
Message 3 of 8
jhackney1972
You can add evenly separated lines along the elliptical curve and dimension.  Someone will be using a ship's curve or other device to lay it out so all they have to do is joint the points.
John Hackney, Retired
Message 4 of 8
JDMather
I didn't open your file, but my first thought is to import dimensions from the part sketch.
Message 5 of 8
sezak99
I investigated that option, but the part itself is created from an angle 8 x 8 x 1.125 inserted into pipe 14' - 0" I.D. under certain angle and then trimmed using "split part using surface". That produces a elliptical curve, but there are no points on the curve except 3 points (2 end points and mid-point) to use as ordinates for subsequent dimensioning.
Instead, I used the 3 available points (2 ends and mid) to create 3-point arc. Then I made elliptical curve invisible. It is close enough for the fabrication of "spiral" lifters.
Message 6 of 8
damian.lewczyk
Autodesk Support
Autodesk Support
Please vote for this idea: https://forums.autodesk.com/t5/inventor-ideas/full-dimension-of-elipse/idi-p/13404028
Damian Lewczyk
Technical Support Specialist
Message 7 of 8
contact
Hi, when I encounter similar problems, I draw a sketch within the drawing view window and create  lines where I want to add dimensions. The workflow is very similar to sketches in a part model.
You create references to the contours.
Now you can add dimensions to the lines of the sketch.
Regards, Jan.
Message 8 of 8
damian.lewczyk
Autodesk Support
Autodesk Support
Yeap, I know this workaround - but this is the only workaround.
Damian Lewczyk
