Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
I practised rendering it took 15 hours but still hasn't completed. But I followed the instructions as per lessons. According to lessons it took only 6 minutes. Please see the attached image ?
Please anyone can explain, why is that take too long time ? It will affect the rendering in my job, if needed ?
Rgds
kelly.young has embedded your image for clarity.
Solved by I_Forge_KC. Go to Solution.
It does not looks correct to me, would you mind share your data to me and project team can debug more.
Emial: xun.zhang@autodesk.com
The single iam file can't be loaded and every component is missing during open.
However, suspect you are using the output option "until satisfactory" and the process will never stop, you can save the image in any time and close the process. In your pdf file, it was talked as notes:
Two ways to handle, one is set the maximum time for each rendering, the second one, just save it in your current setting and cancel the rendering process.
Hope it helps!
Personally I've never see Inventor studio take 6 minutes at all unless you are rendering only a sec or 2 or you are not allowing it to render properly (meaning a very low resolution) at all..
When I render in studio, I process my overall animation in 5 secs increments and depending on my animation/resolution and etc.. I'm looking at a min of 2 to 2 1/2 hours. <-- Sorry I was thinking you were rendering animations in studio. I now see you were just rendering the image.
What lesson are you even looking at that states that? <-- Disregard that.. My browser didn't update and wasn't aware that you had already provided the information. However you have miss-read the information.. Its just states that image was based on the rendering after 6 mins. It doesn't state the rendering finished in 6 mins..
Mark Lancaster
& Autodesk Services MarketPlace Provider
Hi Mark,
Thanks for your reply.
Please let me know How improve rendering time ? Is it because of hardware components Ex: RAM, GRAPHICS CARD etc.,
Rgds
Hello @lkirit2000 just a bit of housekeeping, if you attach an assembly.iam we need all the parts.ipt as well. Would be better to perform a Pack & Go as .zip.
It really depends on the strength of your computer on how fast you can render. There is an ongoing post about Inventor Speed if you want to get more in depth.
How fast is your Inventor PC really?
It might help to check your System Requirements and make sure you're meeting if not exceeding them.
At times I've used junk computers over the years and run Inventor successfully, but when trying to render I would struggle and have to leave it overnight. If the bar is moving and you're seeing progress it might just be you need a bit of an upgrade to speed up the process.
The computer I have here is a monster and cost a ton so creating renderings is pretty quick, I found an old vise in the forums, set to 1600x1200 @ 400 High Box and it took four minutes twenty seconds.
Hope that provides you with a little more info.
Please select the Accept as Solution button if a post solves your issue or answers your question.
* Ideas * Help * AKN * Updates * Pack & Go * Reset Utility * Repair Install * Customization * iLogic Examples * Autodesk University *
If you want the short and sweet reply to hardware, An I7 or I9 is fine coupled with high end GTX card, 16gb of ram is enough unless you do large assemblies and an ssd is always handy. No need for xeons as they cost alot and have low clock speeds, no need for quadros unless youre a professional and are doing massive renders
Hi
Thanks for your info. What No of GTX card you recommend.
Really It needs Quadcore Processor.
Rgds
Go for a GTX 1070 or above, if your budget allows a TITAN, or even an old titan off ebay etc
I7X or I9X are all 6 cores and above with crazy clock speeds, My 7800X is solid for IV
Be aware that renderings in the Studio Environment or via the Raytracing option in the View tab are both CPU operations and not related to the graphics card. Raytracing operations, in general, are multi-threaded operations, so the more cores you can throw at them, the better.
Inventor, as a design package, requires a balance of clock speed vs cores for optimum performance. Most modeling tasks are coded for single core computing, though certain operations (FEA, drawing views, renderings, etc.) can capitalize on many cores.
Your system topology really depends on what you're looking to achieve. For my day-to-day modeling, I use an I7 8700k (6c/12t) but for my FEA and rendering, I have a dual Xeon 2696v4 (44c/88t). The Xeon workstation looks like a beast from the outside, but when I'm doing single-threaded operations (things like Dynamic Simulation especially), it is crazy slow. The flip side is that with the Xeon machine I can render your same scene to the same 270,000 iterations in under two hours.
K. Cornett
Generative Design Consultant / Trainer
