Dear Members,
Situation:
We as a company use the view representations for explaining installation sequence to factory. In Inventor we create an assembly and make step by step views for the sequence. For the views it is possible to Save Camera position. So when you open a view, it shows the section where it has to look. After this we export the file to DWFx, so our factory can open the file with Autodesk Design Review.
We notice that the camera in the view from DWFx can be a lot more zoomed in or zoomed out. (So far even that the model sometimes can't be seen.) Something that seems off: In DWFx the "Field Of View" has a different number for every view. Is it possible to influence this in Inventor? Or is there an other solution to this problem?
Kind regards,
Maickel
