Include solid parameters using make component
02:48 AM
Hi all,
The products we design mostly consist of sheetmetal parts, which we design in a part file as separate solids, after that we use the 'Make Components' command to derive the lot into sheetmetal template files.
One of the things we have not managed to automate yet with iLogic is filling in the plate thickness.
We tried using an extents measurement, but this does not work when bodies are not parallel to each of the origin planes.
Does anybody know if it is possible to automatically export parameters related to a solid which we can then use in a bit of iLogic code to fill in that value for the sheetmetalstyle?
