Multiple offset
Multiple offset
Message 1 of 12
Multiple offset
How can I create multiple offset? The parameters are the quantity and spacing
Replies (11)
Message 2 of 12
CCarreiras
Hi!
You have to create one at the time.
CCarreiras
Message 3 of 12
Does anyone write iLogic that would solve this problem?
Message 4 of 12
JDMather
Attach your file here.
I suspect  you are not using the correct Inventor terms or techiniques.
Message 5 of 12
I have no file. I just want a tool offset used for multiple offset, for example, offset the circle 30 times every 5 mm
Message 6 of 12
Mark.Lancaster
@Anonymous
And after you do that, what are your doing next with these numerous circles?
Mark Lancaster
Message 7 of 12
I projected geometry on the curved surface for a specific CNC machining on 5 axis machine
Message 8 of 12
Mark.Lancaster
@Anonymous
If you provide an example of what you're trying to accomplish maybe we can offer another suggestion.
If you don't even have a part or an example how do you suspect that we are going to assist you?
Mark Lancaster
Message 9 of 12
mcgyvr
Sounds like you need better CAM software..
You shouldn't need to create each tool path in a sketch.. That should just be automatic in the CAM software..
I'm assuming these circles are the path that the tool should follow..
http://www.autodesk.com/products/cam/features/inventor-hsm/3-axis-5-axis-machining/5-axis-multiaxis-operations
Message 10 of 12
Message 11 of 12
The solution is to make a projection on the curved surface of multiple offset.
This is reason why I need help with multiple offset
Message 12 of 12
Curtis_Waguespack
Hi kresimir.belec,
I looked at this and could not figure it out quickly, and unfortunately don't have the time to pursue it further, but if you create a new post on the Inventor Customization forum:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
.... and reference the example below, and ask how to modify this example to be able to use it while selecting an existing profile, I think that someone can provide an iLogic solution.
Please link the new inquiry to this one (and visa versa) to aid in future searches.
I hope this helps.
Curtis
' Check to make sure a sketch is open.
If Not TypeOf ThisApplication.ActiveEditObject Is PlanarSketch Then
	MessageBox.Show("A sketch must be active.", "iLogic")
    Exit Sub
' a reference to the active sketch.
Dim oSketch As PlanarSketch
oSketch = ThisApplication.ActiveEditObject
' a reference to the transient geometry collection.
Dim oTransGeom As TransientGeometry
oTransGeom = ThisApplication.TransientGeometry
' Create a rectangle
Dim oRectangleLines As SketchEntitiesEnumerator
oRectangleLines = oSketch.SketchLines.AddAsTwoPointRectangle( _
                                            oTransGeom.CreatePoint2d(0, 0), _
                                            oTransGeom.CreatePoint2d(10, -10))
' Create a new object collection
Dim oCollection As ObjectCollection
oCollection = ThisApplication.TransientObjects.CreateObjectCollection
' Add the first sketch line of the rectangle to the collection
oCollection.Add(oRectangleLines.Item(1))
' Get the sketch normal
Dim oNormalVector As UnitVector
oNormalVector = oSketch.PlanarEntityGeometry.Normal
' Get the direction of the sketch line being offset
Dim oLineDir As UnitVector2d
oLineDir = oRectangleLines.Item(1).Geometry.Direction
Dim oLineVector As UnitVector
oLineVector = oTransGeom.CreateUnitVector(oLineDir.X, oLineDir.Y, 0)
' The cross product of these vectors is the
' natural offdirection for the sketch line.
Dim oOffsetVector As UnitVector
oOffsetVector = oLineVector.CrossProduct(oNormalVector)
' Get the desired offvector (the +ve y-axis)
Dim oDesiredVector As UnitVector
oDesiredVector = oTransGeom.CreateUnitVector(0, 1, 0)
Dim bNaturalOffsetDir As Boolean
If oOffsetVector.IsEqualTo(oDesiredVector) Then
    bNaturalOffsetDir = True
Else
    bNaturalOffsetDir = False
oOffset = InputBox("Enter an offset distance (in centimeters).", "iLogic", "5")
oCount = InputBox("Enter the number of offsets.", "iLogic", "1")
i = 1
Do Until i = oCount+1
oDistance = oOffset*i
Call oSketch.OffsetSketchEntitiesUsingDistance _
(oCollection, oDistance, bNaturalOffsetDir, True)
i = i + 1
Loop
