Message 1 of 25
- Mute
- Permalink
- Report
I currently do this with a suffix to the dimension. That works well enough usually. The issue I am having now is with a dimension that displays alternate units. The alternate unit is wider than the regular dimension which causes the symbol (") to be spaced off the regular dimension. I wish I could just display the unit string, but for some reason the unit string for inch is (in) in Inventor. I would like to change this so the unit string would be (") instead of (in).
Matt
Inventor 2009 Edited by: [email protected] on Aug 21, 2009 6:47 AM
Matt
