Inventor Forum
Inactive Extrude
1 REPLY 1
baliasM74U3
360 Views, 1 Reply
Inactive Extrude
Hi All
INV2018
Can any experts help me to understand why the extrude function is inactive whereas the extrude cut option is only active.
Pic attached.
1 REPLY 1
imajar
in reply to: baliasM74U3
It is because you are in the assembly environment.  In assembly, you can only made cuts with the extrude feature.
If you need to extrude a new feature, you will need to enter the part where you want that new feature (by either opening it, or edit in context).  Or create a new part for the new feature and then place it in your assembly.
Aaron Jarrett, PE
Inventor 2019 | i7-6700K 64GB NVidia M4000
LinkedIn
Life is Good.
