In-Context / top down modelling WITH configurations
- Mute
- Permalink
- Report
Hi All,
This is my first proper post. I am a new Inventor user coming over from Solidworks and struggling to find a workflow equivalent in Inventor to that which I have used to good effect in Solidworks.
(I have searched all over the internet but found nothing that quite gets me to where I want to be. Perhaps I am just looking for the wrong Inventor terms - I don’t know!)
So the concept:
Is it possibly to have an assembly with components that have features defined in the context of that assembly but where some of those components may also have variations that the assembly can then switch between in order to create assembly variations - all while not breaking any of those in-context references (as they remain constant throughout)?!
Example – a chair:
A specific example (but a good one I hope for this type of work flow) is a chair with three different heights – low, medium, tall (referring in this case to the back heights).
- The chair side frames (lower case ‘h’ shape) have these three heights (low, medium, tall).
- However the side frames also need holes for the chair rails but these holes need to be driven by a sketch (or other components) in the main assembly.
- These holes can be made as required in the chair side frame part referencing the said assembly sketch or other parts.
- These holes can then be configured within the side frame part to be suppressed or computed as required for the different chair height (just go with me on that! 😊 )
- Back in the assembly, different assembly configurations can now be created – i.e. low chair assembly will use the low chair side frame etc etc.
- In use - when the assembly configuration is changed to the ‘medium’ height version, those in-context features remain un altered (as they are used for all side frame versions) - i.e. it is just the chair back height that changes.
- This also mean if the size of those rails changes in the main assembly driving sketch / parts, then this change will be reflected across all those side frame versions.
- Bonus point / next step (FYI): I would then create a mirror of the side frame part and then configurations within that mirror that look to their relevant counterpart from the main side frame.
In Inventor speak – given my current limited knowledge - this might be “assembly sketch drives features in iPart Master, which then in turn filter down to the iPart member variations. The main assembly can then be turned into an iAssembly to drive which iPart member is used for which assembly configuration”.
I give you my dilemma! 😕
Any advice will be hugely appreciated.
Thank you,
Oliver
