Importing STEP file, part name "Document"
cizart_
Message 1 of 25
cizart_
2023 version has a problem that while importing step file , Part number allways comes with name "Document".
Previous version named files by file name.
Replies (24)
Message 21 of 25
cizart_
Can't agee with that.
If I open this file in 2021 version, than it is no problem. Part name = File name.
If there is nothing to do, than maby 2024 version will solve this problem.
Message 22 of 25
johnsonshiue
Hi! Many thanks for your patience! I tried it on 2021, 2022, and 2023. Indeed, there is a change in behavior on 2023.  You are right. "Part Number" used to be empty but now it seems to grab the number from #135. I need to check with the project team and see if this change is intended and for what purpose.
Thanks again!
Software Test Engineer
Message 23 of 25
johnsonshiue
Hi! I did get confirmation from the project team. Indeed, it was an intended change to properly honor the STEP spec. According to STEP spec, the first argument is the product ID (Part Number). In your case, it is "Document."
ENTITY product;
description : OPTIONAL text;
frame_of_reference : SET [1:?] OF product_context;
END_ENTITY;
Many thanks!
Message 24 of 25
cizart_
2024 version has the same issue.
Nothing changed 😔
Message 25 of 25
SBix26
As you can see from the previous reply it is not an "issue"; it is working as intended.  No surprise at all that 2024 behaves the same.
Sam B
Inventor Pro 2024 | Windows 10 Home 22H2
