Importing Solid Edge assemblies slow
mikko.m
Message 1 of 10
mikko.m
Importing Solid Edge assemblies is really slow, over half an hour. For example I have an assembly which contains seven parts and each of them loads instantly but loading the assembly seem to freeze at certain point.
Is there anything else I could try besides this:
https://knowledge.autodesk.com/support/inventor-products/troubleshooting/caas/sfdcarticles/sfdcartic...
Solid Edge ST9
_____________________________________________________________________________________
Inventor Professional 2019.3
Vault Workgroup 2019.1.1
Replies (9)
Message 2 of 10
Xun.Zhang
Hello @mikko.m,
The importing process more like case by case and specific to several data, Would you mind share the data to me so that we can take a closer look?
Thanks!
Xun
Message 3 of 10
Xun.Zhang
Hmm...
Super fast in my end with just 1 second to complete the import process. see -
https://autode.sk/2OGexj6
Please let me know what's the different between us.
By the way, I am working on Inventor 2019.1.
Thanks!
Xun
Message 4 of 10
mikko.m
I guess the difference is the version. I have 2018.3 and you 2019.1. Parts load quickly for me also but the assembly hangs. There is no other settings in Inventor regarding import?
Other problem which is probably related to first one is that I also have a bigger assembly as reference and now it has unresolved components. Only way fix it is probably to just re-import it but then I lose all the constraints.
I will try to get the 2019 version but it might take couple of weeks. When I get it I will report here to see if it works.
Message 5 of 10
Xun.Zhang
Hello Mikko,
I don't think those two problems are related.
Try Right click the top assembly node, Select Resolve file in the context menu and find the source files. Does it helps?
Thanks!
Xun
Message 6 of 10
mikko.m
No help from that.
Message 7 of 10
Xun.Zhang
Then, please show me the file and I can take a look.
Thanks!
Xun
Message 8 of 10
mikko.m
It's 800mb and 20 000 files.
Message 9 of 10
Xun.Zhang
Hello Mikko,
Please just show me below six source files.
Thanks!
Xun
Message 10 of 10
Xun.Zhang
Hello Mikko,
After looking into the data, it seems Vault reference file missing case.
Please get (check out is not needed) all reference source files to local workspace and place from local workspace, it can ease your pain.
Hope it helps!
Xun
