Importing JT issue, please help.
Catherine.Delasko
Catherine.Delasko
I import the JT and it creates assemblies but nothing shows up.
CGBenner
@Catherine.Delasko
Welcome!  What version of Inventor are you using for this? (always a good idea to share this in a post)
Can you share the JT file here?  If so, just attach it to your reply.
Chris Benner
Gabriel_Watson
Use Navisworks to open and verify the JT file if you can. See if you have any other readers to open this and test that it is not empty.
Did you select all object filters to import? Most likely the data would come in as a mesh.
Catherine.Delasko
Thank you, it was meshes I knew it had to be simple.  I appreciate your help.
joshua_whiteVYZP5
Community Visitor
Community Visitor
I have all selected and still am seeing nothing. This is all *.jt files I'm trying to open.
johnsonshiue
Hi Joshua,
A quick test to try. Upload the jt file to viewer.autodesk.com. Does it work? If it does, it will be an Inventor bug. If the viewer cannot display anything in  the jt file, it is likely a limitation in our JT translator or there is a problem with the JT file itself. Also try using JT2GO to see if the file can be viewed properly.
Many thanks!
Software Test Engineer
johnsonshiue
Hi Joshua,
Many thanks!
