Message 1 of 13
Hello
i am importing coordinates of point via excel file but inventor does not converts into sketch. Any suggestions?
Hello
Hi
The only options I know, is the "File Open options"
You can change the import options to Create lines or Splines.
This is available in both 2D and 3D sketch
Inside a sketch, you'll need to pick "Insert Points"
Yeah i tried that. but my points were not joined by line. is there something which i am missing?
1- create a sketch
2- Insert Points function
3- pick Excel sheet in the format where the first column has X values and second column has Y values
4- pick "Options" before you hit "Open" and select Create Lines (or Spline if preferred).
Hi! Please share your Excel spreadsheet. It should work both in 2D Sketch and 3D Sketch.
Many thanks!
Create a 3D sketch
Insert points by pick the sheet with option to include lines between points:
FYI a few points were ignored since they were coincidental:
Hi
I don't have any Screen-cast software installed, so I made a small video for you.
You beat me to it first =D
