Importing excel file
priyada
Message 1 of 13
priyada
Hello
i am importing coordinates of point via excel file but inventor does not converts into sketch. Any suggestions?
Replies (12)
Message 2 of 13
rhasell
Hi
The only options I know, is the "File Open options"
You can change the import options to Create lines or Splines.
This is available in both 2D and 3D sketch
Reg
2026.1
Message 3 of 13
priyada
for me  that option is not getting highlighted.
Message 4 of 13
Gabriel_Watson
Inside a sketch, you'll need to pick "Insert Points"
Message 5 of 13
priyada
Yeah i tried that. but my points were not joined by line. is there something which i am missing?
Message 6 of 13
Gabriel_Watson
1- create a sketch
2- Insert Points function
3- pick Excel sheet in the format where the first column has X values and second column has Y values
4- pick "Options" before you hit "Open" and select Create Lines (or Spline if preferred).
Message 7 of 13
johnsonshiue
Hi! Please share your Excel spreadsheet. It should work both in 2D Sketch and 3D Sketch.
Many thanks!
Software Test Engineer
Message 8 of 13
priyada
okay I have attached the file
Message 9 of 13
Gabriel_Watson
Create a 3D sketch
Insert points by pick the sheet with option to include lines between points:
FYI a few points were ignored since they were coincidental:
Message 10 of 13
rhasell
Hi
I don't have any Screen-cast software installed, so I made a small video for you.
Reg
2026.1
Message 11 of 13
rhasell
LOL, you beat me to it.
Reg
2026.1
Message 12 of 13
Gabriel_Watson
You beat me to it first =D
Message 13 of 13
priyada
thank you all
