Importing Beam Section Libraries
JeffW2026
JeffW2026
I am trying to import the attached library of aluminum sections which should include square web section properties. When I import the library into the "Content Center Libraries" but when I do, I get a yellow "!" and when I try to select one of the square web c-channels I do not see them.
John_Holtz
Autodesk Support
Autodesk Support
This looks like a question for the Inventor forum, so I will move it to that board.
John
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
Michiel.Valcke
You need to migrate the library to your current version. The library is for a 2016 version of Inventor.
Once you do that you'll find the contents there (I created a new filter to show only the Aluminum Association content)
JeffW2026
Thank you, @Michiel.Valcke!
