Imported Revit file in Drawing
stu_bas
stu_bas
I have imported a Revit file as a Reference Model with all the categories (doors, etc). No problem so far.
The issue comes when I create a drawing from the assembly. Suddenly, all the categories disappear so I can't turn them on and off in the drawing. Any ideas?
SharkDesign
This is just the way it works. With reference all the parts are contained inside the assembly .iam which is not how Inventor normally works, this is to make sure the update process works correctly. There is obviously no code in the drawing environment to essentially 'unzip' these files for you to see them individually.
  Inventor Certified Professional
stu_bas
OK. Thanks for the response. I'll make sure to get my views set up correctly before I create the drawing.
