Import STEP files and lose right click bug?
danmachen
Message 1 of 10
danmachen
After I import a non Inventor file type into the .iam assembly model, I lose right click options.
This is the procedure I'm following and its super repeatable.
1. Open a .iam assembly model with some existing files inside.
2. Save a .STEP (or .sldprt or .igs, etc.) into my working directory.
3. Drag and drop this file into the assembly model window.
4. Place a constraint on the imported file (Inventor says the file must be saved first)
5. Save the assembly.
6. Right click does not work.
Dan Machen
Ideas that need support:
Circular / Rectangular Point Matrix
Allow Axis & Plane Selection on Rectangular / Circular pattern
Graphical iLogic Programming
Replies (9)
Message 2 of 10
JDMather
What version of Inventor (including Update number)?
Message 3 of 10
johnsonshiue
Hi Dan,
I cannot seem to reproduce it on 2021.1 update. Please make sure all critical Windows updates are installed and the applicable Inventor updates are installed.
Many thanks!
Software Test Engineer
Message 4 of 10
davis.j
Please fix this issue for future Inventor versions.
I have this issue on Build 245, Release: 2021.1.2 - Date: Fri 09/25/2020
Message 5 of 10
SBix26
Current update for Inventor 2021 is 2021.4.2.  Install the .4 update, followed by the 4.2 update.
A video or series of screenshots would be helpful for anyone trying to reproduce your issue.
Sam B
Inventor Pro 2023.1 | Windows 10 Home 21H2
Message 6 of 10
johnsonshiue
Hi Folks,
I believe this is similar to the following thread. Finally, we are able to reproduce it and it has been reported as INVGEN-63342.
https://forums.autodesk.com/t5/inventor-forum/rmb-right-mouse-button-not-working/m-p/11326080
Many thanks!
Message 7 of 10
andreas.jonssonF98YC
Same issue in inventor 2022.
Message 8 of 10
johnsonshiue
Hi! I just check the status of INVGEN-63342. It remains unresolved.
Many thanks!
Message 9 of 10
ChristiPedersen
We have 1 user experiencing this issue.  I believe we are current on updates for Inventor 2022.  Looking to see if there was a fix or, is there a way for us to check status of INVGEN-63342?
Message 10 of 10
johnsonshiue
Hi Christi,
I just checked the status of INVGEN-63342. It shows it has been fixed on 2023.2 and 2024, but not on 2022. I will work with the project team to see if the fix can be ported back to 2022.
Many thanks!
