Have you tried importing with the healer on (or off, as may be the case)? If
the shape is complex I can't recommend use of the healer in IV, but try it in
MDT where you can turn off the spline tangency healer option and increase the
Simplify tolerance a couple of hundred thou or even up it to .001. It will
sometime help.
Also, while in MDT, run AmSanityCheck on the part (but you knew that, didn't
you ).
"John Bilton(home)" wrote in message
news:1FE69CD96AFC126D9FF2577BC4E3127A@in.WebX.maYIadrTaRb...
> I've got an interesting SAT file from yesterday, it came in fine, it looks
spot on. I can edit base feature to delete
> holes etc, but I try and create a Sketch on any of the flat faces it comes
up a message about invalid sketch axis
> orientation, please redefine. If I sketch on an origin plane it's OK but
when I try and extrude, it comes up with the
> same message.
> Wierd, I'm gonna try and do some "messing" with it in MDT to see if it comes
through properly.
> John Bilton
