Inventor Forum
Import from 3D Autocad file
8 REPLIES 8
Message 1 of 9
phLGMAM
333 Views, 8 Replies
Hi
Hope you can help me. Its importen for me, Thanks in front. I have a lot of files so i need a way to do it.
I really need this type of 3D made file importet to a god 3D inventor file. so it can be shaded and render.
8 REPLIES 8
Message 2 of 9
Hi @phLGMAM
This is result after importing in Inventor
Straight part of your conveyer are missing. I took brief look on AutoCAD file and there is some problems with that block references.
Message 3 of 9
Hi @nedeljko.sovljanski
Thanks for looking.
And yes i have problems with the block. I get the files from some where else and need to use them in Inventor. I can not ask for another file, i have only the files i allready got.
I need them in translated best posible way to Inventor so i can shade and Render.
Message 4 of 9
JDMather
in reply to: phLGMAM
@phLGMAM wrote:
I can not ask for another file, i have only the files i already got.
Fortunately the geometry is very simple and will not take you long to remodel in Inventor.
Message 5 of 9
phLGMAM
in reply to: JDMather
Hi @JDMather
You only see like 0.01% of my total 3D model so NO im not going to redraw it!
I need a way to translatet it into Inventor so i can shade/render all of it.
Best Regards
Message 6 of 9
Hi @phLGMAM
I suggest you to ask on AutoCAD forum what is problem with block and why can not be exploded.
Message 7 of 9
phLGMAM
Hi
I repeate my quistion.
"I really need this type of 3D made file importet to a god 3D inventor file. so it can be shaded and render."
AnyCAD in Inventor? Or another way? Have some one worked with this type of file before and succeeded?
Best regards
Message 8 of 9
johnsonshiue
Hi! Another quick test you can try. In AutoCAD, use ACISOUT or STEPOUT to export the solid. Then import it to Inventor. Do the solid bodies appear?
It is possible those rails may not be solid bodies. Use LIST command to check what they are.
Many thanks!
Software Test Engineer
Message 9 of 9
phLGMAM
in reply to: johnsonshiue
Thanks @johnsonshiue
But no, it take a lot but not all of it. And allso, it really take a long long time and the result are not ad all god enough.
So i STOP this quistion since i can not find a solution that are usefull.
Thanks to you for helping.
Best regards
Peter - Denmark
