IMPORT .DWG FILE TO INVENTOR MESSES UP SCALE
mustafaSNRRQ
Message 1 of 22
mustafaSNRRQ
I have .dwg file where the dimensions are in inches and i imported it into inventor where the dimensions are in inches as well. In the .dwg file i measure a line and it was 9.16 in , but in inventor after importing it was 3.145 in.
How can i fix that?
Replies (21)
Message 2 of 22
JDMather
Can you Attach *.dwg file here that exhibits this behavior?
Message 3 of 22
mustafaSNRRQ
Message 4 of 22
JDMather
@mustafaSNRRQ wrote:
…. In the .dwg file i measure a line and it was 9.16 in...
Please show image.
When I use the Distance command in AutoCAD - this is what I see.
AutoCAD Distance CommandAutoCAD Distance Command
Message 5 of 22
mustafaSNRRQ
I attached below a picture. Basically its the same drawing as the one shown earlier but i deleted the dimensions and some lines.
Message 6 of 22
JDMather
That is not the same *.dwg file that you attached here.
Dimstyles can be changed to read anything.
When you alter the problem - you confuse the issue.
Why did you alter the problem.
You stated Measure?
Message 7 of 22
JDMather
Can you post image of your DIMSTYLE settings?
Message 8 of 22
mustafaSNRRQ
Message 9 of 22
mustafaSNRRQ
The scale is 1.0 for both by the way.
Message 10 of 22
JDMather
This would be so much easier and more efficient if you would simply Attach the correct *.dwg file here before you altered it by deleting the dimensions that you showed in your image that you are relying on.
Note that the image you Attached in your latest post has a scale factor of 80 applied to the dimensions.
(And I assume this is for metric representation of dimensions (but not the correct technique) not even shown in your previous image.)
Attach the correct un-altered dwg file here and end all doubt.
The file that shows the dimensions that you are relying on as factual.
Message 11 of 22
mustafaSNRRQ
I already fixed the scale to 1.0 and the problem is still there.
Message 12 of 22
mustafaSNRRQ
The scale is set to 1.0 and i tried to measure the line shown in the pic below, but its still different than the original dimension.
Message 13 of 22
JDMather
What problem?
There is no problem?
The geometry is what it is.
You have still not Attach the correct *.dwg file here?
Why are you ignoring repeated requests to attach the file with the information that you are relying on?
Message 14 of 22
mustafaSNRRQ
I already uploaded it. But here it is again below attached.
Message 15 of 22
JDMather
Attach this file here and end all doubt.
Message 16 of 22
JDMather
Do you see a new Attachment?
Message 17 of 22
mustafaSNRRQ
How did you do that?
Message 18 of 22
JDMather
Attach the *.dwg file here and end all doubt.
Message 19 of 22
JDMather
Oh wait a minute, you are carrying on two different discussions.
https://forums.autodesk.com/t5/inventor-forum/dwg-2d-to-inventor-3d/m-p/8649685#M736398
To avoid confusion you should keep a discussion within a single thread rather than starting new threads.
I have found the issue and will post video when it is done compiling.
Message 20 of 22
JDMather
Turns out that this was a simple case of someone not understanding how to use AutoCAD and manually overriding dimensions.
I could have solved this in about 30 seconds if the correct *.dwg displaying the incorrect dimensions had been attached in the initial post.
