This would be so much easier and more efficient if you would simply Attach the correct *.dwg file here before you altered it by deleting the dimensions that you showed in your image that you are relying on.
Note that the image you Attached in your latest post has a scale factor of 80 applied to the dimensions.
(And I assume this is for metric representation of dimensions (but not the correct technique) not even shown in your previous image.)
Attach the correct un-altered dwg file here and end all doubt.
The file that shows the dimensions that you are relying on as factual.
