Message 1 of 13
10:07 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I placed several bearings from Content Center and I want to place them on shafts with Insert constraint. I have the following rule that works:
SyntaxEditor Code Snippet
Dim oAssyDoc As AssemblyDocument oAssyDoc = ThisApplication.ActiveDocument Dim oOcc1 As ComponentOccurrence Dim oOcc2 As ComponentOccurrence Dim bearing_name As String=Parameter("category4")+":1" oOcc1 = Component.InventorComponent(bearing_name) oOcc2 = Component.InventorComponent("shaft1") Dim oPartDef1 As PartComponentDefinition oPartDef1 = oOcc1.Definition Dim oPartDef2 As PartComponentDefinition oPartDef2 = oOcc2.Definition Dim iMate1 As iMateDefinition iMate1 = oPartDef1.iMateDefinitions.Item(2) Dim iMate2 As iMateDefinition iMate2 = oPartDef2.iMateDefinitions.Item(8) Dim oEntity1 As Object Dim oEntity2 As Object Call oOcc1.CreateGeometryProxy(iMate1.Entity, oEntity1) Call oOcc2.CreateGeometryProxy(iMate2.Entity, oEntity2) Dim colCons As AssemblyConstraint colCons = oAssyDoc.ComponentDefinition.Constraints.AddInsertConstraint(oEntity1, oEntity2, 1, 0)
The problem is on this line
No2 reprezent the index number of the iMate constraint of the bearing from CC. (one of the insert constraints)
But sometimes the index number is different, 1 to 5.
I want to be able to define iMate1 as the name of the constraint "Insert In1" and not the index number. Somthing like this
iMate1 = oPartDef1.iMateDefinitions.name("Insert In1")
but is not working
