Hi!
Here is a friend of mine – iMan, the model of the human which I found on the internet.
I need to make his back flat, like a plane.
I don’t understand how to accomplish that.
The assembly is attached
Thank you in advance!
Solved by JDMather. Go to Solution.
What version of Inventor are you using?
(These parts were last save in version 2010.)
What happens if you Edit Sketch11 and make the spline flat for a straight spine? (Pun intended.)
Thanks, there is no need to reply.
I have converted the spline into CV spline and then used the trim command
I deleted the constraint at the "midpoint".
Added a construction line from end to end.
Added coincident constraint from spline node to construction line.
I didn't download iMike,
but it seems to me that iMike is an improved version of iMan.
Isn't it?
Thanks anyway!
You have a man, why leave out a woman?
http://www.cbliss.com/inventor/Parts.htm
Exactly that.
I used iJill recently as part of a workbench layout to check that controls were in a convenient place. When I went through the design with the operator, I had to spend the first 10 minutes changing iJill's hair & tunic colour until the operator was happy.
