I have written the following code:
If SCsupportRight = "No" Then MessageBox.Show(" I will add them for you.")
The parameter SCsupportRight is a multivalue parameter which contains:
- "Yes"
- "No"
After the messagebox i want iLogic to set the parameter "SCsupportRight" to the value "yes" automatically.
I cant find the code which sets a multivalue parameter to a specific value.
Any help?
Solved by kgilham. Go to Solution.
Try the following
If SCsupportRight = "No" Then MessageBox.Show("I will add them for you") Parameter("SCsupportRight") = "Yes" End If
Let me know if this works for you.
kgilham wrote:
Try the following
Nope. The value isn't changing.
Interesting, that was working on my end. Would you mind attaching the part you are working on? It would help me make sure I am going through the same workflow that you are.
I was working on another part of the iLogic file and for some unknown reason now your solution seems to work :).
Thanks!
