Ilogic Script for Highlight Defind A-Side and set the appearance ?
willemTHLQC
willemTHLQC
Hello, I need some help using Ilogic the select Defind A-Side and the set a appearance  to it
I want to use this for setting up Diamant/tear Plate type of materiaals  and have the other sides blank
Any one any ideas how to do this?
MjDeck
Here's a sample:
Sub Main
	Dim partDoc As PartDocument = ThisDoc.Document
	Dim compDef As SheetMetalComponentDefinition = partDoc.ComponentDefinition
	If (compDef.HasFlatPattern) Then
		Dim flat = compDef.FlatPattern
		Dim foldedFace = flat.ASideFace.ASideFace
		If (foldedFace IsNot Nothing) Then
			For Each faceX As Face In flat.ASideFace.Faces
				'partDoc.SelectSet.Select(foldedFace)
				SetFaceColor(faceX, "Orange", partDoc)
			Next
		End If
	End If
End Sub
Sub SetFaceColor(face As Face, appearanceName As String, partDoc As PartDocument)
	Dim asset As Asset = Nothing
	Try
		asset = partDoc.Assets.Item(appearanceName)
	Catch
		Dim assetLib = ThisApplication.AssetLibraries.Item("314DE259-5443-4621-BFBD-1730C6CC9AE9")  '("Autodesk Appearance Library")
		asset = assetLib.AppearanceAssets.Item(appearanceName)
		asset = asset.CopyTo(partDoc)
	End Try
	'Logger.Info("Asset name = {0}", asset.DisplayName)
	face.Appearance = asset
End Sub
Mike Deck
Software Developer
Autodesk, Inc.
willemTHLQC
Thank you MjDeck ,
this works great for me
