- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello Inventor Forum Community,
This is my first post on the forum, though I've been reading it a long time. My question is similar to others posted but I cannot find anything exact as this:
I automate drafting for my company with Ilogic. No one else in the company understands Ilogic at all. I have a particular Ilogic Assembly referencing 12 ipts, with an easy to use form that is the only thing that will be touched by the other draftsmen. I need to find an easy way for them to save a particular configuration of the assembly, with a different file name, without the Vault.
I've tried Pack-n-Go and it seems to work, but is very tedious for the other draftsmen, and once they change the component names in explorer, the rules are thrown completely out of whack as they no longer reference that file name.
ILogic Design Copy seems like a good thing to try but that is also very tedious to the drafstmen working, and they have a hard time working with the project files to find all the needed components.
I'm sure the above is a bit confusing so let me just try to break it down to the minimum:
-Copy an Ilogic configuration and save it with a completely different file name
-Cannot use the Vault
-The new configuration does not need to have rules. i.e. if you could use the rules to change the assembly, and then save that assembly and child parts without rules, that would be fine.
I appreciate any help you all can give. Feel free to ask me to explain soemthing furthur.
Nicholas
