Inventor Forum
iLogic - save as stl in mm with high quality
3 REPLIES 3
1703 Views, 3 Replies
Hi All,
I would like to save stl files in mm and high quality. This is easily done manually, by changing the settings in the options bar, but when iLogic saves as an stl it reverts back to saving in cm with standard quality.
I'm using this to autosave:
ThisDoc.Document.SaveAs(ThisDoc.ChangeExtension(".stl"), True)
Any help, greatly appreciated.
3 REPLIES 3
t_hascj
Hi c.pikket,
Please, try this code:
sTLname = ( "D:\LOD\PART001.STL" )
Dim oTranslator As TranslatorAddIn
oTranslator = ThisApplication.ApplicationAddIns.ItemById("{533E9A98-FC3B-11D4-8E7E-0010B541CD80}")
Dim oContext As TranslationContext
oContext = ThisApplication.TransientObjects.CreateTranslationContext
Dim oOptions As NameValueMap
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
If oTranslator.HasSaveCopyAsOptions (ThisApplication.ActiveDocument, oContext, oOptions) Then
oOptions.Value("ExportUnits") = 5 'Millimeter
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
Dim oData As DataMedium
oData = ThisApplication.TransientObjects.CreateDataMedium
oData.FileName = sTLname
oTranslator.SaveCopyAs(ThisApplication.ActiveDocument, oContext, oOptions, oData)
https://forums.autodesk.com/t5/inventor-forum/ilogic-generating-stl-files-in-millimeters-and-with-a-...
Jaroslav
in reply to: t_hascj
Hello Jaroslav,
Thank you for your help.
I'm just wondering if this will save the stl file with the name of the part or will it always save it with the same file name?
I'm looking for it to be saved with the same file name as the part.
Thanks 🙂
Hi Jaroslav,
With a bit of editing it works beautifully:
Format:HTML Format Version:1.0 StartHTML: 165 EndHTML: 8679 StartFragment: 314 EndFragment: 8647 StartSelection: 314 EndSelection: 314SyntaxEditor Code Snippet
sTLname = ThisDoc.ChangeExtension(".stl")
oOptions.Value("Resolution") = 0 'High
Thanks 🙂
