Hi All
I am new to the forum, this is my first post.
I want to save a idw drawing file as the part number, of the part in the drawing sheet.
I have made a start on this but with no success as yet, this is what I have
ThisDoc.Document.SaveAs (iProperties.Value(("Project", "Part Number"(".idw"),True:)
thought it would give you an idea of what I am trying to do.
The brackets got out of hand, yes I am new to the ilogic thing! Thanks
Solved by Curtis_Waguespack. Go to Solution.
@Anonymous
If this iLogic snippet is located in your drawing file, then the information from Project/Part Number is coming for the drawing iProperties information and not from your part. I assume you want to save the IDW based on the part properties that are in the base view of the drawing, is that correct?
You will need additional code to pull the information of the component off the base view. Which will need VB programming commands... I will tag @Curtis_Waguespack to see if he already has such a code.
Mark Lancaster
& Autodesk Services MarketPlace Provider
Thanks mark
Yep I want the part number from the part in the drawing sheet. I'm toggling through an I part table so I want to just run all rules then toggle to the next variation of the part and repeat . Thanks
@Anonymous wrote:
Thanks mark
Any reason you need a separate drawing for each ipart?
Can't you just do a tabulated drawing like this?
HI
All parts need a part number and separate drawing so we can vault everything and analyse costs automate production and most important of all,
its not up to me!.
any idea on the code?
Hi J.Tofts,
Here's a quick example.
I didn't test it much (or at all with iParts), or try to catch any issues that might arise if for the part number iprop is empty, etc.
But it should get you started.
Also just as a tip, you can search and ask programming questions of this type on the Inventor Customization forum too:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
I hope this helps.
Curtis
'get model doc oModleDoc = ThisDrawing.ModelDocument 'process file name 'get position of the last backslash Dim FNamePos As Long FNamePos = InStrRev(oModleDoc.FullFileName, "\", -1) 'get file name Dim docFName As String docFName = Right(oModleDoc.FullFileName, Len(oModleDoc.FullFileName) - FNamePos) 'define the property set oDTPs = oModleDoc.PropertySets.Item("Design Tracking Properties") 'define the property oPN = oDTPs.Item("Part Number").Value 'replace old file name with iproperty value oPathAndName = Replace(oModleDoc.FullFileName,docFName,oPN) 'save off a copy ThisDoc.Document.SaveAs(oPathAndName & ".idw" , True) 'present message to user MessageBox.Show("File saved to: " & oPathAndName & ".idw", "iLogic")
Hi Curtis
Rule worked, Much appreciated
I have a couple of your books so to get my first problem solved by you is a good start to the day.
Can you recommend some literature for me to get to grips with the code side of inventor, I am currently building models with ilogic and all seems straight forward, its the curve ball element when VB is required.is there a book of rules, yes I 'm old school I like the book element.
Again, Thank you so much. I really appreciate all your help.
@Anonymous wrote:
HI
its not up to me!.
Not sure why those stated needs force you to a drawing for each member.. But whatever..
Hi Mark
I do see the advantage of tables in drawing and appreciate the suggestion.
I am using Autodesk Inventor
I know this sounds like a lot of messing around but our company makes a product with standard parts and part numbers which are also the drawing numbers. Once all part and assembly's are complete it will drastically reduce design time with ilogic driving the GA's
I hope this helps
This code saves a copy of the drawing with the part number as file name. Is it possible to save the current idw drawing in the same way? (save, not save copy as)
is it possible to add a part title to this code from iProperties so that when it records the part number and title.
Thank you
