I have an assembly file with a "height" and "width" parameter. I have a part file with the same "height" and "width" parameters. In my assembly file, I have created an ilogic rule that sets the part file parameters equal to the assembly file parameters so I can update these values directly from the assembly.
I want to use the assembly file/ part files to save as new files and simply adjust the parameters. Is there any way to set the code to update with the new file name when I replace the part file "P" with a new file rather than having to go into it and manually type in the new part name?
