If these rules were locally saved in your template files then are you sure your current project file/application options are pointing to the correct template files?
Go to File...Manage.. Projects and hover over the "Templates" section under Folder Options to see the location of the template files its using and ensure thats where your templates that you were using in the previous version were saved at... If it says "Default" and that not where your templates were then you can set that default in tools..application options.. file tab.. Or set it directly in your project file to overwrite that application options location.
