iLogic rule to change parameter to a driven dimension
Hi everyone,
I'd like to create what seems to be a fairly straightforward rule. Here is my code so far:
If hinge = 0 Then
d380 = 235mm AND "is a driving dimension"
d430 "is a driven dimension" ElseIf hinge = 1 Then
d380 "is a driven dimension"
d430 = 235mm AND "is a driving dimension"
End If
See below image for some additional info. I basically want the hole to move to the left side of the part when hinge=1 & the right side of the part when hinge=0iLogic driven dimension.JPG
Craig
BrandonBG
Why not just draw both holes and suppress one when hinge=1 and suppress the other when hinge=0?
You don't need to write a rule for this. Right-click on the hole feature in the browser and you can set up suppress/unsuppress based on the value of hinge.
BrandonBG
Thanks Brandon, that's a lot simpler Smiley Happy
