09:57 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm attempting to create a rule using iLogic, which reads the first two letters of either the File Name or Part number (Which ever is easier)
i.e. if a part number was AB12345, I would want the code to recognize the "AB"
At which point I'm trying to use an If-Then-Else statement to modifiy the material of the part, dependent on the first two characters of the File name.
Is this possible?
As an example, where the underlined portion is what i don't know how to code:
If iProperties.Value("Project", "Part Number") Begins with "AB" Then
iProperties.Material = "Steel"
Else If iProperties.Value("Project", "Part Number") Begins with "AC" Then
iProperties.Material = "Aluminum"
End If
-Dan
Link copied
