I dont want to print directly from code but simply open the "print drawing" tab via iLogic
Any ideas,
Solved by Curtis_Waguespack. Go to Solution.
Hi LewisLusby,
You can use this line to programatically "push" the print button:
ThisApplication.CommandManager.ControlDefinitions.Item("AppFilePrintCmd").Execute
Also just a tip: you might have better luck searching and asking questions of this type on the Inventor Customization forum:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
I hope this helps.
Curtis
Is there a way to catch this command before it executes?
Example: I want to use an iLogic form that is triggered via the iTrigger that users have to prompt to select what kind of print this is "RELEASE, REFERENCE, or DRAFT" once there selection is made the the form exits, the "Plot Stamp" in the title block is updated based on the selection and the print window is excuted with this command.
Now I have all this worked out but being that this isnt a perfect world the problem is users still sometimes click the print button which does not prompt them for the print type which is a problem. Which is why I am wondering if a user clicks the print button I can prompt the iLogic form before the print options window comes up?
Thank you
