I am using iLogic to make a parts list with a specific format to the parts list. However, this format uses groupings that I want to programatically turn off. How do I do this? These are the lines that set the parts list...
SyntaxEditor Code Snippet
PartList = oSheet.PartsLists.Add(oDrawingView, oPlacementPoint, PartsListLevelEnum.kPartsOnly) oPartList.Style = oDrawDoc.StylesManager.PartsListStyles.Item("CUT SHEET (Yargus)")
In the parts list style, I want to deactivate the groups (see pic) without having to modify the CUT SHEET template itself.
Solved by Curtis_Waguespack. Go to Solution.
Hi allen.knapp,
I looked and didn't see anything in the API to suggest that we can access those settings programatically. Some old threads suggest it wasn't exposed in the API, and seem still not to be:
http://forums.autodesk.com/t5/inventor-customization/group-settings-in-parts-list/m-p/1755699#M17883
http://forums.autodesk.com/t5/inventor-customization/parts-list-override/m-p/2142050#M23257
I hope this helps.
Curtis
